- В этой теме 9 ответов, 2 участника, последнее обновление 4 года, 9 месяцев назад сделано
Алексей.
01.05.2021 в 16:25 #30020
I don’t what else to do, solder every earth connection, put new wire,s to sensor check voltage everywhere ,chack every resistance , early I have change o2 sensor several time’s, even I put distancer for sensor, I do everything what people in this site tell, only maybe catalyst or ecu, maybe new flash , same friends make a joke to sell lacetti and no more problems, But car is very good 2010year, only 40000 km almost new. Can somebody send to me flash for ecu and will I have problems with immobileser , please give opinion to me. Thanks to members of this forum
01.05.2021 в 21:38 #30025There’s the link to post, how you can try to solve the problem — https://www.drive2.ru/b/527374431144640709/
I think you can make translation, and you can ask any time in this theme. People tell there is no increased fuel consumption or any other visible problems with it
03.05.2021 в 19:42 #30027thank you friend,
04.05.2021 в 20:03 #30038Good luck!
05.05.2021 в 07:40 #30041It is not problem The circuit, yesterday I have analysis the problem so this is happening: at start engine up sensor is going 98% heating and for 2 second hi start from 0,4 to0,7 to0,2 voltage, at same time down sensor heating oscillating from 40 to 98% several times but voltage of sensor is not switching from 0,7 to 0,1 for about 2 minutes hi is floating and ecu is full time at 98 % and error 036 Is generate. Down sensor is good condition I have changed several times, for checking I have put him in before catalyst hi works fast,
Same thing is cooling my down sensor I don’t know what is it.
05.05.2021 в 12:40 #30042Your catalyst is working? I’m out of catalyst, first (up) sensor disabled, EGR disabled too, second sensor actually reliable enough. I have flashed to EURO2 and have no problem, only when I wash the engine and wet the connectors
I’m not deal with voltages, didn’t get in it so deep, so can’t say…. May be your catalyst is out of order?…
06.05.2021 в 18:32 #30059Yes for shure catalyst is not working ,so how can I flash to euro 2 Wich software do I need I can somebody give me flash and give me explanation How to do that
07.05.2021 в 12:31 #30077It’s not so easy, you must have specific equipment and software, and flash file, and understanding what to do
I went to electrician, he made dump of my original flash, send it to programmist, and then flash the new file to my Lach
08.05.2021 в 09:16 #30085Friend of course that I need software and interface , but from experience when somebody put new flash it will have extra problems: air-conditioning, immobileser, Key will not working, after some time passed car will not work fine,
On that post some gay put bulb lamp to wire of heater : that is not working because ecu reed temperature of catalyst from heating element resistance (ptc resistor is oxigen sensor)
09.05.2021 в 16:37 #30097About extra problems — specialist must do the flash, I have no problem with it. About immobiliser — I think it flashed in other hard block (between front seats). About bulb lamp to heater — I’m not try it, can’t say. I just suggest, you need to decide…
